I use OpenOffice 3.3 in a windows XP system, a XAMPP with MySQL 5.5.8 and ODBC 3.51 installation (as BASE database access mode ODBC or ODBC MySQL).
When I define a VIEW as a virtual table in MySQL with all rights for the user, I am able to see the fields of the view in the tables of BASE, I am able to send an INSERT command in the SQL field of the BASE frontend to add a new field but I could NOT find a way to add a value through the BASE frontend table directly. The status of the table remains as view only.
Any suggestions to overcome this trouble ?
the openoffice forum says that BASE sets autonomously the access to any VIEW always to read-only, which is difficult to understand. Any comments or differences in libreoffice BASE ....
andy
BASE as frontend for MySQL views
AndreasJBittner
- ! Supporter - Spende !
- Kontaktdaten:
Re: BASE as frontend for MySQL views
Hi Andy,
this is a feature, not a failure. A VIEW is nothing more than a SELECT-statement and produces a virtual table, the result set. How should an insert work on a result-set? You have to insert your new data into the table.
Greetings
Andreas
Greetings
Andreas
LO 7.5.1.2
iMac Retina 5K, 27", 3,3 GHz 6-Core i5, 64 GB /MacBook Pro, 8 GB RAM, Mac OS X 13.2.1 (22D68)
MySQL 8.0.28
MySQL 8.0.28
Hi Andreas,
if you check the MySQL (and many other SQL) databases you will see that VIEWS can be treated like regular tables although they are virtual tables. I use these type of table to regulate access to the tables behind instead of column access roles because you can define VIEW access roles like regular tables.
you can define a VIEW and try to set an INSERT via direct BASE SQL command - it works well
AndreasJBittner
- Kontaktdaten:
ok, I see, but if the VIEW is a view across some related tables you have to define the relationship as ... on delete | insert cascade; if 'no action' is defined no action will proceed. Have a look at
http://dev.mysql.com/doc/refman/5.5/en/ ... aints.html
Greetings
Andreas
Greetings
Andreas
LO 7.5.1.2
MySQL 8.0.28
MySQL 8.0.28
the read-only setting occurs also if you do not use complex JOIN request to form the VIEW.
