ich möchte per Makro ein Tabellenblatt in ein neues Dokument kopieren. Die Formatierung soll übernommen werden.
Anstelle der Formeln sollen aber nur die Werte kopiert werden.
Ich habe schon verschiedenes probiert:
mit
Sub Export()
Dim Sheet As Object
Sheet = ThisComponent.Sheets.getByName("xxx")
ThisComponent.CurrentController.setActiveSheet(Sheet)
dim document as object
dim dispatcher as object
document = ThisComponent.CurrentController.Frame
Dim args1(2) as new com.sun.star.beans.PropertyValue
args1(0).Name = "DocName"
args1(0).Value = ""
args1(1).Name = "Index"
args1(1).Value = 1
args1(2).Name = "Copy"
args1(2).Value = true
dispatcher.executeDispatch(document, ".uno:Move", "", 0, args1())
' CopyPaste(Sheet , oSheet_Ziel , "A1:AA100", "A1:AA100")
End Submit
Sub CopyPaste(oSheet_Quelle As Object, oSheet_Ziel As Object, Range_Quelle As String, Range_Ziel As String)
Dim DatArray
DatArray = oSheet_Quelle.getCellRangeByName(Range_Quelle).getDataArray
oSheet_Ziel.getCellRangeByName(Range_Ziel).setDataArray(DatArray)
End Sublaut A. Pitonyak sollte es folgendermaßen gehen
Sub Main
Dim sNewURL$ 'URL For a NEW calc document "private:factory/scalc"
Dim oNewDoc 'New Document
Dim oFrame 'Frame that can perform the dispatch
Dim oDispatcher 'The dispatcher to use
Dim oSheet 'The current active sheet
Dim i% 'General Index Variable
Dim iActive% 'Currently active sheet
REM This will copy FROM ThisComponent
oFrame = ThisComponent.CurrentController.Frame
oDispatcher = createUnoService("com.sun.star.frame.DispatchHelper")
oSheet = ThisComponent.CurrentController.getActiveSheet()
iActive = -1 : i = 0
Do While iActive < 0
If ThisComponent.Sheets(i).Name = oSheet.Name Then
iActive = i
Else
i = i + 1
End If
Loop
sNewURL = "private:factory/scalc"
oNewDoc = StarDesktop.loadComponentFromURL(sNewURL, "_blank", 0, Array())
Dim args(2) as new com.sun.star.beans.PropertyValue
args(0).Name = "DocName"
args(0).Value = "Untitled1" 'This copies to the document named Untitled1
args(1).Name = "Index"
args(1).Value = iActive
args(2).Name = "Copy"
args(2).Value = True 'Set to Flase to perform a Move
oDispatcher.executeDispatch(oFrame, ".uno:Move", "", 0, args())
End Subargs(0).Value = "Unbenannt 1" versucht, das klappt aber so nicht.
CopyByNameCode: Alles auswählen
importsheetIn Excel sieht der funktionierende Code folgendermaßen aus:
Sub Export()
' Export Makro
' Ausschließlicher Export des Blattes "xxx"
Sheets("Klassifizierung").Select ' Auswahl des Tabellenblatts mit Namen "xxx"
Cells.Select ' alle Zellen des Blatts auswählen
Selection.Copy ' alle Zellen kopieren
Workbooks.Add ' neue Datei erstellen und hinzufügen
' Blattinhalte und -formatierungen einfügen
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
Selection.PasteSpecial Paste:=xlPasteFormats, Operation:=xlNone, _
SkipBlanks:=False, Transpose:=False
Sheets("Tabelle1").Select 'Tabellenblatt umbenennen
Sheets("Tabelle1").Name = "Export"
Range("B1").Select
Application.CutCopyMode = False
ActiveWorkbook.Close savechanges:=True
End SubHat wohl jemand nen Tip für mich...?
Gruß Thomas
