BaseReportExtension Support und Discussion [en,de]
charlie.it
Re: BaseReportExtension Support und Discussion [en,de]
Beitrag von charlie.it » Mi 11. Jan 2017, 11:54
Ok, thank you.
I also prepared the .odt file in Italian, if you want to add it in the extension documentation.
I leave to you to complete the extension with texts in Italian that i wrote.
guida_rapida_basereportextension.odt
(496 KiB) 330-mal heruntergeladen
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » Mi 11. Jan 2017, 19:17
8-) :ugeek: excellent work! I can do the update tomorrow! Grazie!
g
charlie.it
Beitrag von charlie.it » Sa 14. Jan 2017, 09:20
Ciao @gogo,
I do not understand why I get SQL error with the query of this file. If instead of the name of the query as Value for the table of the file .ott, use its SQL content, everything works.
Thanks.
Country.odb.zip
(22.91 KiB) 322-mal heruntergeladen
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » Sa 14. Jan 2017, 10:17
Ciao Charlie
what error exactly?
I've attached a file which contains 2 *.otts and the odt-file.
In both otts there're 2 tables, the first is referring to the queryname, the second takes the SQL-String.
Extract them to one directory and open the database, Formular1 has a button to open a report based on BRX_Test01.ott.
If you open BRX_Test02.ott klick on the Button and both tables will fill (if any of your Country.odb's is a registered datasource named "Country").
Country.odb_with_otts.zip
(43.69 KiB) 327-mal heruntergeladen
g
charlie.it
Beitrag von charlie.it » Sa 14. Jan 2017, 11:04
Oh! thank you.
I found my error with your help: I wrote the error string: Cuntry.select * from “WorldAreaReport” instead: WorldAreaReport.
Thank you again.
LibreOffice 4.3.7
Mac OSX 10.7.5
charlie.it
Beitrag von charlie.it » Sa 14. Jan 2017, 11:30
Ciao,
also point out this thread from me open on the English AOO forum: https://forum.openoffice.org/en/forum/v ... 86#p406161.
@Villeroy compares your extension with the one written by him in Python, and more ...
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » Sa 14. Jan 2017, 14:31
thanks - I didn't kow about his extension - wrote that over there...
g
charlie.it
Beitrag von charlie.it » So 15. Jan 2017, 09:26
Ciao, I'm still here to demand an explanation :D .
I can not get to work the custom property „brx.save_to_url“.
Schermata 01-2457769 alle 09.23.30.png (33.21 KiB) 7516 mal betrachtet
Schermata 01-2457769 alle 09.22.52.png (19.81 KiB) 7516 mal betrachtet
Can you please post a file with an example where it works?
Thanks.
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » So 15. Jan 2017, 13:51
sry - there's a mismatch between documentation and code: use brx.savetourl instead of brx.save_to_url!
g
charlie.it
Beitrag von charlie.it » So 15. Jan 2017, 15:21
Same result, unfortunately. What does it mean "report is set invisible" ?
LibreOffice 4.3.7
Mac OSX 10.7.5
