BaseReportExtension Support und Discussion [en,de]
gogo
Re: BaseReportExtension Support und Discussion [en,de]
Beitrag von gogo » So 15. Jan 2017, 16:33
I think there are properties missing. SystemAbort is at the moment just called when the array that should contain the user-defined properties is empty.
to test the export, just add this property
to the file BRX_Test01.ott
g
charlie.it
Beitrag von charlie.it » So 15. Jan 2017, 16:45
You're right, I had just discovered it myself. But, perhaps, it is necessary to modify the quick reference ….
Thanks.
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » So 15. Jan 2017, 17:04
the code of the extension has to be modified too. There's no problem if you either start from within a saved document or if a path is submitted in brx.savetourl (e.g.: "/tmp/Report2.pdf"). But if you start the report from within a not saved doc and there's no path supplied the extension can not find a location to save the pdf - unfotunately: if you open an ott-document, you allways have a unsaved doc ...
g
charlie.it
Beitrag von charlie.it » Mo 16. Jan 2017, 08:52
I attach a new corrected version of the quick_reference in Italian:
guida_rapida_basereportextension.odt
(483.3 KiB) 384-mal heruntergeladen
I also tried the "brx.pdfviewer" property but it does not work in Mac OSX with the default program "Anteprima" (with or without path).
Schermata 01-2457770 alle 08.45.15.png (44.07 KiB) 8459 mal betrachtet
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » Mo 16. Jan 2017, 09:42
I think "Users/Applications/Anteprima" is not a valid commad on Mac. Try
which anteprima
or
which Anteprima
to get the right path - at least on Linux this will work - Macs should be similar
If you got the command, try it inside the extension. The viewer is called by the BASIC-"shell"-command. If it doesn't work you can test different commands like this:
shell("/command/that/launches/Anteprima",,"/path/to/your/pdf",false)
ps: maybe Macs are cASe sESNitIVe?
thx for the update, but atm it's not possible to upload pdfs, odts or other documentation on the extensions homepage...
g
charlie.it
Beitrag von charlie.it » Mo 16. Jan 2017, 17:10
Found trying and trying, the right command for OSX is:
open -a Preview
Where "Preview" is the name of the app for Italian application "Anteprima".
To the next time ...
LibreOffice 4.3.7
Mac OSX 10.7.5
dmaths
Beitrag von dmaths » Di 17. Jan 2017, 12:26
Hi, I use a button in a form of my basefile, and enter the name of the myreport.ott-file without path, because it is in the same directory as mybasefile.odb.
It produces the following error:
file:///C:/Users/myname/Desktop/mydir/mybasefile.odb\myreport.ott NICHT gefunden!
i.e. BRX adds the name of the mybasefile.odb to the path, as if it was a subdirectory -
plus a funny mix of / and \...
gogo
Beitrag von gogo » Mi 18. Jan 2017, 09:36
The LO-Macro "DirectoryNameoutofPath()" of the "tools" library requires path and separartor. BRX provides "\" on Win-Systems and "/" on all other operating systems ... unfortuantely you have to use "/" on Win-Systems too - I don't know if this was intended by the programmer of DirectoryNameoutofPath(). The bug is removed in brx v 0.1.1, which is not released so far, because I can not supply any documentation-files on the extensions-libreoffice-homepage at the moment. (if I release 0.1.1, the doc-files for 0.1.0 will not be shown any more which makes the extension unusable)
If you use the full path, the extension will work.
To have a way around:
BRX supports multiple paths, separated by ";" - so you can use one Button for Win, Linux and Macs - BRX simply uses the first file that can be found:
"C:\Files\MyTemplate.ott;/mnt/N/Reporttemplates/MyTemplate.ott;MyTemplate.ott"
Will work for Win-Systems where there's a C:\Files\MyTemplate.ott, for Linux-Systems where tehre's a /mnt/N/Reporttemplates/MyTemplate.ott, and with BRX v 0.1.1 for all systems where the ott-file is in the same directory as the odb...
g
charlie.it
Beitrag von charlie.it » Do 19. Jan 2017, 18:49
Ciao,
I'm here again.
in the new example that I attached, there are two problems:
  1. The decimal point is always a point (.) instead of a comma (,) like Italian setup. Both formatting the numbers of the table "#. ###, 00" and "#, ###. 00"
  2. The calculated fields in a a query (showing 2 decimal places) are with 4 decimal in the report although formatted in the manner described above.
Can you solve? Thanks.
Test.zip
(17.68 KiB) 361-mal heruntergeladen
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » Do 19. Jan 2017, 21:51
hi charlie,
there's at the moment no support for conversion of types - and I think there will never be one (because this would be a never-ending-story).
You've to format almost everything inside your query (which by the way gives you full control what is shown in the report).
SELECT "ID", "Price", "Price" * 1.234 "Tot" FROM "Table1" AS "Table1"
should be
SELECT "ID", "Price", REPLACE( "Price" * 1.234, '.', ',' ) "Tot" FROM "Table1" AS "Table1"
If you need currency,:
SELECT "ID", "Price", '€ ' || REPLACE( "Price" * 1.234, '.', ',' ) "Tot" FROM "Table1" AS "Table1"
Then even calculations will work!
g
