BaseReportExtension Support und Discussion [en,de]
Re: BaseReportExtension Support und Discussion [en,de]
I think there are properties missing. SystemAbort is at the moment just called when the array that should contain the user-defined properties is empty.
to test the export, just add this property to the file BRX_Test01.ott
g
- charlie.it
You're right, I had just discovered it myself. But, perhaps, it is necessary to modify the quick reference ….
Thanks.
Thanks.
LibreOffice 4.3.7
Mac OSX 10.7.5
Mac OSX 10.7.5
the code of the extension has to be modified too. There's no problem if you either start from within a saved document or if a path is submitted in brx.savetourl (e.g.: "/tmp/Report2.pdf"). But if you start the report from within a not saved doc and there's no path supplied the extension can not find a location to save the pdf - unfotunately: if you open an ott-document, you allways have a unsaved doc ...
g
- charlie.it
I attach a new corrected version of the quick_reference in Italian:
I also tried the "brx.pdfviewer" property but it does not work in Mac OSX with the default program "Anteprima" (with or without path).
LibreOffice 4.3.7
Mac OSX 10.7.5
Mac OSX 10.7.5
I think "Users/Applications/Anteprima" is not a valid commad on Mac. Try
to get the right path - at least on Linux this will work - Macs should be similar
If you got the command, try it inside the extension. The viewer is called by the BASIC-"shell"-command. If it doesn't work you can test different commands like this:
ps: maybe Macs are cASe sESNitIVe?
thx for the update, but atm it's not possible to upload pdfs, odts or other documentation on the extensions homepage...
which anteprima
or
which AnteprimaIf you got the command, try it inside the extension. The viewer is called by the BASIC-"shell"-command. If it doesn't work you can test different commands like this:
shell("/command/that/launches/Anteprima",,"/path/to/your/pdf",false)thx for the update, but atm it's not possible to upload pdfs, odts or other documentation on the extensions homepage...
g
- charlie.it
Found trying and trying, the right command for OSX is:
Where "Preview" is the name of the app for Italian application "Anteprima".
To the next time ...
open -a PreviewTo the next time ...
LibreOffice 4.3.7
Mac OSX 10.7.5
Mac OSX 10.7.5
Hi, I use a button in a form of my basefile, and enter the name of the myreport.ott-file without path, because it is in the same directory as mybasefile.odb.
It produces the following error:
file:///C:/Users/myname/Desktop/mydir/mybasefile.odb\myreport.ott NICHT gefunden!
i.e. BRX adds the name of the mybasefile.odb to the path, as if it was a subdirectory -
plus a funny mix of / and \...
The LO-Macro "DirectoryNameoutofPath()" of the "tools" library requires path and separartor. BRX provides "\" on Win-Systems and "/" on all other operating systems ... unfortuantely you have to use "/" on Win-Systems too - I don't know if this was intended by the programmer of DirectoryNameoutofPath(). The bug is removed in brx v 0.1.1, which is not released so far, because I can not supply any documentation-files on the extensions-libreoffice-homepage at the moment. (if I release 0.1.1, the doc-files for 0.1.0 will not be shown any more which makes the extension unusable)
If you use the full path, the extension will work.
To have a way around:
BRX supports multiple paths, separated by ";" - so you can use one Button for Win, Linux and Macs - BRX simply uses the first file that can be found:
"C:\Files\MyTemplate.ott;/mnt/N/Reporttemplates/MyTemplate.ott;MyTemplate.ott"
Will work for Win-Systems where there's a C:\Files\MyTemplate.ott, for Linux-Systems where tehre's a /mnt/N/Reporttemplates/MyTemplate.ott, and with BRX v 0.1.1 for all systems where the ott-file is in the same directory as the odb...
g
- charlie.it
Ciao,
I'm here again.
in the new example that I attached, there are two problems:
I'm here again.
- The decimal point is always a point (.) instead of a comma (,) like Italian setup. Both formatting the numbers of the table "#. ###, 00" and "#, ###. 00"
- The calculated fields in a a query (showing 2 decimal places) are with 4 decimal in the report although formatted in the manner described above.
- Test.zip
- (17.68 KiB) 362-mal heruntergeladen
LibreOffice 4.3.7
Mac OSX 10.7.5
Mac OSX 10.7.5
hi charlie,
there's at the moment no support for conversion of types - and I think there will never be one (because this would be a never-ending-story).
You've to format almost everything inside your query (which by the way gives you full control what is shown in the report).
should be
If you need currency,:
Then even calculations will work!
SELECT "ID", "Price", "Price" * 1.234 "Tot" FROM "Table1" AS "Table1"Code: Alles auswählen
SELECT "ID", "Price", REPLACE( "Price" * 1.234, '.', ',' ) "Tot" FROM "Table1" AS "Table1"Code: Alles auswählen
SELECT "ID", "Price", '€ ' || REPLACE( "Price" * 1.234, '.', ',' ) "Tot" FROM "Table1" AS "Table1"g
