My Conversion from VBA to Basic did not work properly - maybe theres another Attribute than Ranges?
TorbenIT
Beitrag von TorbenIT » Di 6. Apr 2021, 09:58
    Range("B9").Select
    Selection.Copy
    Range("A13").Select
    Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
        :=False, Transpose:=False
    Range("B6").Select
    Application.CutCopyMode = False
    Selection.Copy
    Range("B13").Select
    Range("B7").Select
    Selection.Cut
    Range("C13").Select
    ActiveSheet.Paste
    Range("B8").Select
    Selection.Cut
    Range("D13").Select
    ActiveSheet.Paste
    Range("B7:B8").Select
    Selection.NumberFormat = "#,##0.00 $"
    Rows("13:13").Select
    Selection.Insert Shift:=xlDown, CopyOrigin:=xlFormatFromLeftOrAbove
    Range("B13:D13").Select
    With Selection.Interior
        .Pattern = xlNone
        .TintAndShade = 0
        .PatternTintAndShade = 0
    End With
    Range("B6").Select
Sub CopyKontoCell
	Dim bezeichnung as Variant
	oSheet1 = ThisComponent.Sheets.getByIndex(0) 'ThisComponent = ActiveWorkbook
	 REM Get the range to copy and the rang to copy to.
  	oRangeOrg = oSheet1.getCellRangeByName("B5").RangeAddress
  	oRangeCpy = oSheet1.getCellRangeByName("B19").RangeAddress
  	  REM Do the copy
 	 oSheet1.CopyRange(oCellCpy, oRangeOrg)
Sub CopyDatumCell
	Dim inp as Variant
  	oRangeOrg = oSheet1.getCellRangeByName("B8").RangeAddress
  	oRangeCpy = oSheet1.getCellRangeByName("A19").RangeAddress
  	  inp = oRangeCpy
  	  inp = CDate(inp)
  	  REM Do the copy
 	 oSheet1.CopyRange(oCellCpy, inp)
Sub CopyEinnahmeCell
	Dim einnahme@
  	oRangeOrg = oSheet1.getCellRangeByName("B6").RangeAddress
  	oRangeCpy = oSheet1.getCellRangeByName("C19").RangeAddress
  	einnahme@ = oRangeCpy
  	  REM Do the copy
Sub CopyAusgabeCell
  	oRangeOrg = oSheet1.getCellRangeByName("B7").RangeAddress
  	oRangeCpy = oSheet1.getCellRangeByName("D19").RangeAddress
  	  REM Do the copy
Re: My Conversion from VBA to Basic did not work properly - maybe theres another Attribute than Ranges?
Beitrag von mikele » Di 6. Apr 2021, 14:26
hier https://de.openoffice.info/viewtopic.php?f=18&t=75399 geht es um etwas/das Gleiche.
Ein bisschen mehr Input wäre schon sinnvoll.
Beitrag von mikele » Di 6. Apr 2021, 14:42
da es (glaube ich) nur um das Übertragen von Inhalten geht, würde doch so etwas reichen:
	 oSheet1.getCellRangeByName("A19").String=oSheet1.getCellRangeByName("B8").String
bzw.
	 oSheet1.getCellRangeByName("A19").Value=oSheet1.getCellRangeByName("B8").Value
Beitrag von mikele » Di 6. Apr 2021, 14:57
um alle 4 Werte zu übertragen
	osheet1=ThisComponent.Sheets.getByIndex(0)
	aDaten = oSheet1.getCellRangeByName("B5:B8").getDataArray()
	aDatenNeu=Array(Array(aDaten(3)(0),aDaten(0)(0),aDaten(1)(0),aDaten(2)(0)))
	oSheet1.getCellRangeByName("A19:D19").setDataArray(aDatenNeu())
TorbenIT
Beitrag von TorbenIT » Di 6. Apr 2021, 15:16
Ja, habes es mittlerweise selbst hinbekommen, aber danke dir!
Wie es aussieht, bist du ein Libre Office Basic Experte - willst du dir etwas dazu verdienen? Da ich noch mehrere Makros hätte, die in Basic übertragen müssten.
Beitrag von mikele » Di 6. Apr 2021, 16:14
für größere Projekte habe ich leider keine Zeit. Wir machen das hier rein privat aus Spaß an der Freude und als Hilfe zur Selbsthilfe.
Das, was du hier so beschrieben hast sind aber eher kleine Codeschnipsel - wie bereits geschrieben: ein bisschen mehr Input wäre hilfreich.
