Datei Exportiert als PDF
Atwist
Beitrag von Atwist » Mo 14. Sep 2015, 19:06
Ich versuche einen Knopf mit Macro zu machen dass meine Datei Exportiert als PDF mit Name aus einen Celle zum Beispiel H1
Mit Excel kenne ich mich ein bissen aus.
REM  *****  BASIC  *****
sub PDF
rem define variables
dim document   as object
dim dispatcher as object
dim args1(2) as new com.sun.star.beans.PropertyValue
args1(0).Name = "URL"
args1(0).Value = "file:///media/archief/ANDRE%20MAP/" .Range("Data.H1").Value & ".pdf"
args1(1).Name = "FilterName"
args1(1).Value = "calc_pdf_Export"
args1(2).Name = "FilterData"
args1(2).Value = Array(Array("UseLosslessCompression",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Quality",0,90,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ReduceImageResolution",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("MaxImageResolution",0,300,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("UseTaggedPDF",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SelectPdfVersion",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportNotes",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ViewPDFAfterExport",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportBookmarks",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("OpenBookmarkLevels",0,-1,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("UseTransitionEffects",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("IsSkipEmptyPages",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("IsAddStream",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("FormsType",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportFormFields",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("AllowDuplicateFieldNames",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerToolbar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerMenubar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerWindowControls",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ResizeWindowToInitialPage",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("CenterWindow",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("OpenInFullScreenMode",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("DisplayPDFDocumentTitle",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("InitialView",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Magnification",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Zoom",0,100,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PageLayout",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("FirstPageOnLeft",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("InitialPage",0,1,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Printing",0,2,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Changes",0,4,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EnableCopyingOfContent",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EnableTextAccessForAccessibilityTools",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportLinksRelativeFsys",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PDFViewSelection",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ConvertOOoTargetToPDFTarget",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportBookmarksToPDFDestination",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignPDF",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("_OkButtonString",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Watermark",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EncryptFile",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PreparedPasswords",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("RestrictPermissions",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PreparedPermissionPassword",0,Array(),com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureLocation",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureReason",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureContactInfo",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignaturePassword",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureCertificate",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE))
dispatcher.executeDispatch(document, ".uno:ExportToPDF", "", 0, args1())
end sub
Habe einen kleinen teil auf die Excel Methode geändert aber es funktioniert immer noch nicht.
args1(0).Value = "file:///media/archief/ANDRE%20MAP/" .Range("H1").Value & ".pdf"
Was hab ich falsch gemacht?????
Schöne grüße aus Twist
Schöne grüße aus Emsland
Andreas
Atwist
Re: Datei Exportiert als PDF
Beitrag von Atwist » Di 15. Sep 2015, 07:53
Hallo Nikki,
Du hast recht ich mach einen Umzug nach LibreOffice Programmierung :D
Danke
Andreas
