Understand the principle of small roller maintenance
Qizhenbi
Beitrag von Qizhenbi » Fr 30. Dez 2016, 07:17
Small roller is now indispensable in the construction of engineering compaction machinery, especially in the construction of highway projects, its high technological content, complex structure, because the working environment is different from the professional level of the operating machinery staff are also very different, it is possible The use of small rollers will have different degrees of damage. Want to small roller mechanical damage, failure rate to a minimum, then it should do its maintenance work.Hand single drum roller.
Small roller maintenance work tension is divided into three parts:
1, the daily technical maintenance: the daily use of small rollers, to do a reasonable maintenance, routine maintenance, regular maintenance Baidu snapshot ranking, this can effectively extend the life of small roller, reduce the failure rate, protection Listen to work.
2, periodic maintenance: cycle of the various parts of the small roller maintenance, replacement, in particular, more wear and tear some of the components. Maintenance must be carried out to the designated professional maintenance.
3, long-term parking maintenance: small roller and other machinery is not the same as sports planning, so the long-term parking also for mechanical maintenance. Such as too small anti-corrosion, rust and so on.Driving single drum roller
