VBA to libreoffice question
comandos
Beitrag von comandos » Mo 16. Mär 2020, 12:28
Greetings,
I need a little help editing my existing VBA code to work with libre office.
I would like:
1) to copy errors in column C if the date in the same row in yellow,
2) sort them all by date oldest to newest
3) (if possible) if the button (that triggers the macro is pressed it clears any previous entries in “STATUS” tab).
https://imgur.com/a/GQVmEPv ← example
code
Option Compare Text
Sub getAllErr()
    Dim ws As Worksheet
    Dim lastRow As Integer
    For Each ws In ThisWorkbook.Sheets
        If ws.Name <> "status" Then
            For i = ws.UsedRange.Rows.Count To 2 Step -1
                If ws.Cells(i, 1).Interior.Color = 65535 Then
                    lastRow = ThisWorkbook.Sheets("status").Cells(Rows.Count, 1).End(xlUp).Row
                    ThisWorkbook.Sheets("status").Cells(lastRow + 1, 1) = Format(ws.Cells(i, 1), "Short Date")
                    ThisWorkbook.Sheets("status").Cells(lastRow + 1, 2) = ws.Name
                    ThisWorkbook.Sheets("status").Cells(lastRow + 1, 3) = ws.Cells(i, 3)
                End If
            Next i
        End If
    Next ws
MsgBox "Kopirano"
BR
Re: VBA to libreoffice question
Beitrag von F3K Total » Mo 16. Mär 2020, 18:26
comandos
Beitrag von comandos » Di 17. Mär 2020, 07:54
F3K Total hat geschrieben:
crossposting
My bad, still looking for help.
Beitrag von F3K Total » Di 17. Mär 2020, 18:22
we all lern...
solution in english forum available ...
R
