oDesktop = CreateUnoService("Com.sun.star.frame.desktop")
sUrl ="private:factory/scalc"
oSpreadsheetDocument = _
oDesktop.loadComponentfromURL(sURL, "_blank", 0, mNoArgs())
sUrl ="private:factory/swriter"
oTextDocument = _
Sub Style Basics
Dim ODesktop as Object
Dim ODocument As Object
Dim OText As Object
Dim ODispatcher As Object
Dim OStyleFamilies As Object
Dim oParaghraphStyles As Object
Dim oStyle As Object
Dim n As Integer
end sub
sub style_init
Dim mNoArgs REM empty Sequence
Dim smyText As String
Dim sUrl As String
oDesktop = CreateUnoService ("com.sun.star.frame.desktop")
sUrl= "private:factory/swriter"
oDocument = oDesktop.LoadComponentFromURL(sURL,"_blank",0, mNoArgs[/b]
oText = oDocument.Text
sMyText = "A very short paragraph for illustration only."
oDispatcher = oText.createTextDispatcher ()
oText.insertString(oDispatcher,"Headline",False)
oText.insertControlCharakter(oDispatcher,_
com.sun.star.text.ControlCharacter.Paragraph_Break,FALSE)
oText.insertString(oDispatcher,smyText,False)
End sub
Der fett formatierte Code ist falsch. Wie sollte es richtig heißen?
LG, Johanna
Code
Re: Code
Hallo Johanna,
versuch es mal damit, ungetestet.
Auch hier dier Empfehlung bei Dannenhoefer mal reinzuschaun.
http://www.dannenhoefer.de/faqstarbasic ... l#Zweig133
balu
Dim mNoArgs ()
oDocument = oDesktop.LoadComponentFromURL(sURL,"_blank",0, mNoArgs())
balu
