BaseReportExtension Support und Discussion [en,de]
Re: BaseReportExtension Support und Discussion [en,de]
Beitrag von karolus » Mi 2. Mär 2016, 18:12
nada nix null :oops:
Beitrag von karolus » Do 10. Mär 2016, 20:44
Seit heute kann man die Erweiterung runterladen!
Karolus
robertleleu
Beitrag von robertleleu » Di 26. Apr 2016, 22:38
Being French I'm not sure to understand that libreofficebase 1.5 doesn't accept the last version of reportbuilder.....
Could someone give me the conclusion of your discussions?
Thanks
gogo
Beitrag von gogo » Mi 27. Apr 2016, 08:55
You mean LO 5.1 and the built-in Oracle-ReportBuilder probably. (Which is an extension, but as I know in most Linux-Systems a pre-installed one that is firmly integrated to LO).
The Base-Report-Extension is NOT the Oracle-ReportBuilder - I've tested the Base-Report-Extension (just some minutes ago) on a freshly Kubuntu 16.04 which runs a LO 5.1.2.2 and - beside of the typo :oops: - the extension works fine:
For questions concerning the Oracle-ReportBuilder - please open a new tread and provide exact informations about your operating system, LO-Version, how it and the Oracle-ReportBuilder were installed. And of course some thing like an error message - if any.
My French ist somewhat rotten for 30 years or more ...
à bientôt
g
charlie.it
Beitrag von charlie.it » Sa 7. Jan 2017, 09:22
gogo hat geschrieben:Feel free to ask in english!
Quite by accident I found and downloaded this extension.
Although it was published as early as March 2016, I don't found a reviews on web sites. Have I not looked well?
I was the first to put "I like", I was the first to try it?
Still it works well. I tested with a Query Base with three fields and 9520 records. The running time is quite long (150 seconds) compared with about 30 seconds of Report Builder. But for smaller databases the time is reduced significantly (see chart).
Schermata 01-2457761 alle 09.13.26.png (28.63 KiB) 7023 mal betrachtet
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » Sa 7. Jan 2017, 12:28
Thanks for testing and reviewing ...
The running time depends on your
  1. query-layout
  2. database-layout
  3. report-file complexity and of course on the
  4. ammount of data that is insterted
Ususally one doesn't use a writer-document to present 10.000 records of a query ;). A "report" is used for small tables e.g. for an invoice or if you order 5 items ...
Therefore the extension focuses on table-layout and not on data-export.
All cell-values are inserted one by one using
oWriterTable.getCellByPosition(i,ii).setstring(oResultset.getstring(n))
so huge data-tables are a time consuming thing, of course.
The extension ensures, that
  • all data is shown in the tables (flexible table cells - which is not provided by the ReportBuilder), it can
  • merge cells if there is the same content in adjactent cells, it can
  • combine data from different queries in one report (even if queryX is from in DatabaseX and queryY from DatabaseY!), it can
  • refer queries to data in actually opened Base-forms (e.g. "select * from invoices where id= '###FORMFIELD(<InvoicesForm><id>)###' ")
  • and many more...
If the report is ready the extension can manipulate the report (without an user interaction!): Save to file, save to pdf, mail the report to somebody, call a batch-file (e.g. to copy the report (per ssh etc.) somewhere ...) - or it just returns the report as a Base-object so that programmers can do what ever they want to...
For exporting data formatted to Calc we have done a similar extension, but it's not ready to publish and furthermore just tested for MySQL ...
g
charlie.it
Beitrag von charlie.it » Sa 7. Jan 2017, 15:45
My test was only trying to find the limits ...
I believe that the extension is friendlier than Report Builder, a very good work :!: .
To make it known I talked about it on the English forum of AOO.
I would like to do a review on the AOO Italian forum where I am the administrator.
I think I do a translation into Italian.
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » Sa 7. Jan 2017, 16:58
Thanks for the flowers ;)
... good to know it works on AOO and Mac too :thumbs up:
There's 2 things to translate - the description and the extension itself.
Translation of the description
The description evtl. should be rewritten complete. I reviewed my own document 4 or 5 times, but it's something different to explain all the things to another person...
I think at least 3 people should read it and give suggestions to change it, so it becomes more readable to the public.
Translation of the extension:
There's a sub (BRX_SetLanguage) in the extension that enables translation of the messageboxtexts:
All texts are stored in just one array: la_BRX_text(n,l) - where "n" is the index of the text to use and "l" the index for the language to use. Inside functions and subs texts are retrieved by la_BRX_text(3,li_BRX_Language) where "li_BRX_Language" is a module-local integer that is set by calling ThisComponent.CharLocale.Language.
'**-------------------- BRX_SetLanguage ------
SUB BRX_SetLanguage
' for translation: add an index ad dimension 2 and adjust li_BRX_Language...
' text is called by la_BRX_text( n ,li_BRX_Language)
select case ThisComponent.CharLocale.Language
case "de"
	li_BRX_Language = 1
case else
	li_BRX_Language = 0
end select
la_BRX_text(0,0) = "Reportgeneration is running, plz try again later!"
la_BRX_text(0,1) = "Berichterstellung laeuft derzeit - bitte spaeter nochmal versuchen!"
la_BRX_text(1,0) = "No template defined! Should I take the current document?"
la_BRX_text(1,1) = "Keine Dokumentenvorlage angegeben! Soll das aktuelle Dokument verwendet werden?"
la_BRX_text(2,0) = "Generation of report will be stopped!"
la_BRX_text(2,1) = "Berichterstellung wird abgebrochen!"
la_BRX_text(3,0) = "Data pasted!"
la_BRX_text(3,1) = "Daten eingefuegt!"
la_BRX_text(4,0) = " generated."
la_BRX_text(4,1) = " erstellt."
change the dimension of la_BRX_text (at top of the module from dim la_BRX_text(31,1) to la_BRX_text(31,2) ), and the sub itself to:
SUB BRX_SetLanguage
case "de"
	li_BRX_Language = 1
case "it"
	li_BRX_Language = 2
case else
	li_BRX_Language = 0
end select
la_BRX_text(0,2) = "extension lavora adesso..."
la_BRX_text(1,2) = "...italian text ..."
la_BRX_text(2,2) = "...italian text ..."
la_BRX_text(3,2) = "...italian text ..."
la_BRX_text(4,2) = "...italian text ..."
and it will show up italian texts on italian systems
g
charlie.it
Beitrag von charlie.it » Mi 11. Jan 2017, 09:03
Ciao, I modified the code by inserting the lines in Italian, but I get this error:
Schermata 01-2457765 alle 09.00.47.png (30.43 KiB) 6998 mal betrachtet
SUB BRX_SetLanguage
case "it"
	li_BRX_Language = 2
case "de"
	li_BRX_Language = 1
case else
	li_BRX_Language = 0
end select
la_BRX_text(0,2) = "Report in esecuzione, prego attendere!"
la_BRX_text(1,2) = "Modello non definito!Usare il documento corrente?"
la_BRX_text(2,2) = "Esecuzione report interrotta!"
la_BRX_text(3,2) = "Dati copiati"
la_BRX_text(4,2) = " generato"
la_BRX_text(5,0) = "The proposed path '" '   & sBPfad & +19+25
la_BRX_text(5,1) = "Der vorgeschlagene Speicherpfad '"  +19+25    ' & sBPfad & "') wurde NICHT gefunden! Speichern unter: '"
la_BRX_text(5,2) = "Il percorso proposto"
la_BRX_text(6,0) = "' not possible!"
la_BRX_text(6,1) = "' nicht moeglich!"
la_BRX_text(6,2) = "' non possibile!"
la_BRX_text(7,0) = "You should change the user defined-property 'brx.savetourl' of the template '"
la_BRX_text(7,1) = "Aendern Sie in der Berichtsvorlage '"
la_BRX_text(7,2) = "Si dovrebbe cambiare la proprietà definita dall'utente 'brx.savetourl' del modello '"
la_BRX_text(8,0) = "' to a valid path!"
la_BRX_text(8,1) = "' die benutzerdefinierte Eigenschaft 'brx.savetourl' auf einen gueltigen Speicherpfad!"
la_BRX_text(8,2) = "' a un percorso valido!"
la_BRX_text(9,0) = "Errors occured:"
la_BRX_text(9,1) = "Folgende Fehler sind aufgetreten:"
la_BRX_text(9,2) = "Errore verificato:"
la_BRX_text(10,0) = " not found! - Please fill in a valid path in the .tag-field of the button!"
la_BRX_text(10,1) = " NICHT gefunden! - Bitte unter 'Zusatzfunktion' des Buttons eine gueltige Datei angeben!"
la_BRX_text(10,2) = " non trovato! - Completare con un valido percorso il .tag-field del pulsante!"
la_BRX_text(11,0) = " is not a template for a Writer-document!"
la_BRX_text(11,1) = " ist keine Vorlage fuer ein Writer-Dokument!"
la_BRX_text(11,2) = " non è un modello di documento di Writer!"
la_BRX_text(12,0) = " could NOT be saved! The odt-document will be opened!"
la_BRX_text(12,1) = " konnte NICHT gespeichert werden! Das odt-Dokument wird geoeffnet!"
la_BRX_text(12,2) = " non può essere salvato! Il documento odt sarà aperto!"
la_BRX_text(13,0) = "Error while I tried to open '"
la_BRX_text(13,1) = "Fehler beim Versuch '"
la_BRX_text(13,2) = "Errore nell'apertura '"
la_BRX_text(14,0) = "' with '"
la_BRX_text(14,1) = "' mit '"
la_BRX_text(14,2) = "' con '"
la_BRX_text(15,0) = "'!"
la_BRX_text(15,1) = "' zu oeffnen!"
la_BRX_text(15,2) = "'!"
la_BRX_text(16,0) = "You should change the user defined-property 'brx.pdfviewer' of the template '"
la_BRX_text(16,1) = "Aendern sie ggf. die Benutzerdefinierte Eigenschaft 'brx.pdfviewer' in der Berichtsvorlage '"
la_BRX_text(16,2) = "Si dovrebbe cambiare la proprietà definita dall'utente 'brx.pdfviewer' del modello '"
la_BRX_text(17,0) = "ERROR!!! No datasource defined!"
la_BRX_text(17,1) = "FEHLER!!! Es wurde KEINE Datenquelle definiert!"
la_BRX_text(17,2) = "ERRORE!!! Nessuna fonte dati definita!"
la_BRX_text(18,0) = "ERROR!!! Datasource '"
la_BRX_text(18,1) = "FEHLER!!! Datenquelle '"
la_BRX_text(18,2) = "ERRORE!!! fonte dati '"
la_BRX_text(19,0) = "' does not exist!"
la_BRX_text(19,1) = "' existiert nicht!"
la_BRX_text(19,2) = "' non esiste!"
la_BRX_text(20,0) = "These errors occured yet earlier:"
la_BRX_text(20,1) = "Folgende Fehler sind vorher schon aufgetreten:"
la_BRX_text(20,2) = "Questi errori si sono verificati ancora in precedenza:"
la_BRX_text(21,0) = "table "
la_BRX_text(21,1) = "Tabelle "
la_BRX_text(21,2) = "Tabella "
la_BRX_text(22,0) = ": Merge-UP in cell "
la_BRX_text(22,1) = ": Merge-UP in Zelle "
la_BRX_text(22,2) = ": Incolla nella cella "
la_BRX_text(23,0) = " not possible!"
la_BRX_text(23,1) = " nicht moeglich!"
la_BRX_text(23,2) = " non possibile!"
la_BRX_text(24,0) = " not found in the document!"
la_BRX_text(24,1) = " im Dokument nicht gefunden!"
la_BRX_text(24,2) = " non trovato nel documento!"
la_BRX_text(25,0) = " Save as: '"
la_BRX_text(25,1) = " Speichern unter: '"
la_BRX_text(25,2) = " Salva come: '"
la_BRX_text(26,0) = "ERROR!!! Searching for a form-object only possible when function is called from a button... within that form (oEvent!)"
la_BRX_text(26,1) = "FEHLER!!! es wird nach einem Formular gesucht, das geht aber nur, wenn es einen Bezug dorthin gibt (oEvent!)"
la_BRX_text(26,2) = "ERRORE!!! Ricerca di una oggetto di un form possibile solo quando la funzione viene chiamata da un pulsante ... all'interno di tale form (oEvent!)"
la_BRX_text(27,0) = "open PDF?"
la_BRX_text(27,1) = "PDF oeffnen?"
la_BRX_text(27,2) = "PDF aperto?"
la_BRX_text(28,0) = "An ERROR occured (exit_SystemAbort)"
la_BRX_text(28,1) = "Fehler aufgetreten! (exit_SystemAbort)"
la_BRX_text(28,2) = "Si é verificato un ERRORE  (exit_SystemAbort)"
la_BRX_text(29,0) = "The report is set invisible at the moment"
la_BRX_text(29,1) = "Der Bericht ist derzeit ausgeblendet"
la_BRX_text(29,2) = "Il report è impostato invisibile al momento"
la_BRX_text(30,0) = "close the report?"
la_BRX_text(30,1) = "Bericht schliessen?"
la_BRX_text(30,2) = "chiudere il report?"
la_BRX_text(31,0) = "Error - no path to save in save_to_url property and the following path could not be generated:"
la_BRX_text(31,1) = "Fehler - kein Speicherpfad in save_to_url gefunden - folgendes Verzeichnis konnte NICHT angelegt werden:"
la_BRX_text(31,2) = "Errore - nessun percorso per salvare nella proprietà save_to_url e il seguente percorso non può essere generato: "
END SUB
What did I do wrong?
LibreOffice 4.3.7
Mac OSX 10.7.5
gogo
Beitrag von gogo » Mi 11. Jan 2017, 11:21
the error occurs while calling the sub BRX_SetLanguage and is an index error.
did you change line 100 from
to
dim la_BRX_text(31,2)
... as mentioned here?
change the dimension of la_BRX_text (at top of the module from dim la_BRX_text(31,1) to la_BRX_text(31,2) ), ...
because you can not set "la_BRX_text(0,2) = "Report in esecuzione, prego attendere!"" if la_BRX_text(0,1) is the maximum in the second index.
g
