ich hoffe, das folgende Code Snippet ist die Lösung zu Deinem Problem.
HINWEIS
!!! Ich habe es nicht getestet !!!
REM ***** BASIC *****
Option Explicit
REM ============================================================================
REM
Sub copyValsFromSrc
' Constants
Const iCOL_B As Integer = 1
' Variables
Dim iRowIdx As Integer
Dim iRowIdxEnd As Integer
Dim oSrcCell As Object
Dim oSrcDoc As Object
Dim oSrcSheet As Object
Dim oThisDoc As Object
Dim oThisSheet As Object
Dim sMsg As String
Dim sSrcFileName As String
Dim sSrcPathDir As String
Dim sSrcUrl As String
' Read ini values from spreadsheet 'Sheet2' of This document
oThisDoc = ThisComponent
oThisSheet = oThisDoc.getSheets().getByName("Sheet2")
' Path to source directory
sSrcPathDir = oThisSheet.getCellRangeByName("A1").String
' Name of source file
sSrcNameFile = oThisSheet.getCellRangeByName("A2").String
' Name of required spreadsheet contained by remote/ source file
sSrcNameSheet = oThisSheet.getCellRangeByName("A3").String
' Create URL pointing to source file
sSrcUrl = ConvertToURL(sPathSrcDir + getPathSeparator + sSrcFileName)
' Check if the above file exists
If Not FileExists(sSrcUrl) Then
' Assemble message
sMsg = "ERROR" & Chr(13) & _
"Source file doesn't exist in specified location" & Chr(13) & _
"Path: " & sSrcPathDir & Chr(13) & _
"File: " & sSrcFileName & Chr(13) & _
Chr(13) & _
"Routine is going to terminate"
' Show message
MsgBox sMsg, 0, "Source file doesn't exist"
' Terminate execution
End
End If
' Access source file
oSrcDoc = StarDesktop.loadComponentFromURL(sSrcUrl, "_blank", 0, Array())
' Access spreadsheet 'Sheet1' of source file
oSrcSheet = oSrcDoc.getSheets().getByName("Sheet1")
' FIXME
' Spreadsheet source: get index of 'last' cell which contains a value
' Asign the above value to variable 'iRowIdxEnd'
iRowIdxEnd = 500
' Set row index
For iRowIdx = 0 To iRowIdxEnd Step 1
' Create cell object
oSrcCell = oSrcSheet.getCellByPosition(iCOL_B, iRowIdx)
' Check if cell is empty
If Not oSrcCell.Type = com.sun.star.table.CellContentType.EMPTY Then
' Read value from source cell and write it to This cell
oThisSheet.getCellByPosition(iCOL_B, iRowIdx) = oSrcCell.Value
End If
Next iRowIdx
' Delete objects explicitly (NOT necessary, but I like it)
Set oThisSheet As Object
Set oThisDoc As Object
Set oSrcSheet As Object
Set oSrcDoc As Object
Set oSrcCell As Object
