"gelöst " Datei Exportiert als PDF
Atwist
Beitrag von Atwist » Di 15. Sep 2015, 07:56
Ich versuche einen Knopf mit Macro zu machen dass meine Datei Exportiert als PDF mit Name aus einen Celle zum Beispiel H1
Mit Excel kenne ich mich ein bissen aus.
REM  *****  BASIC  *****
sub PDF
rem define variables
dim document   as object
dim dispatcher as object
dim args1(2) as new com.sun.star.beans.PropertyValue
args1(0).Name = "URL"
args1(0).Value = "file:///media/archief/ANDRE%20MAP/" .Range("Data.H1").Value & ".pdf"
args1(1).Name = "FilterName"
args1(1).Value = "calc_pdf_Export"
args1(2).Name = "FilterData"
args1(2).Value = Array(Array("UseLosslessCompression",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Quality",0,90,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ReduceImageResolution",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("MaxImageResolution",0,300,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("UseTaggedPDF",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SelectPdfVersion",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportNotes",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ViewPDFAfterExport",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportBookmarks",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("OpenBookmarkLevels",0,-1,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("UseTransitionEffects",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("IsSkipEmptyPages",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("IsAddStream",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("FormsType",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportFormFields",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("AllowDuplicateFieldNames",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerToolbar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerMenubar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerWindowControls",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ResizeWindowToInitialPage",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("CenterWindow",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("OpenInFullScreenMode",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("DisplayPDFDocumentTitle",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("InitialView",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Magnification",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Zoom",0,100,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PageLayout",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("FirstPageOnLeft",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("InitialPage",0,1,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Printing",0,2,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Changes",0,4,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EnableCopyingOfContent",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EnableTextAccessForAccessibilityTools",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportLinksRelativeFsys",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PDFViewSelection",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ConvertOOoTargetToPDFTarget",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportBookmarksToPDFDestination",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignPDF",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("_OkButtonString",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Watermark",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EncryptFile",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PreparedPasswords",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("RestrictPermissions",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PreparedPermissionPassword",0,Array(),com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureLocation",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureReason",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureContactInfo",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignaturePassword",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureCertificate",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE))
dispatcher.executeDispatch(document, ".uno:ExportToPDF", "", 0, args1())
end sub
Habe einen kleinen teil auf die Excel Methode geändert aber es funktioniert immer noch nicht.
args1(0).Value = "file:///media/archief/ANDRE%20MAP/" .Range("H1").Value & ".pdf"
Was hab ich falsch gemacht?????
Schöne grüße aus Twist
Zuletzt geändert von Atwist am Mi 16. Sep 2015, 10:24, insgesamt 1-mal geändert.
Schöne grüße aus Emsland
Andreas
Atwist
Re: Datei Exportiert als PDF
Beitrag von Atwist » Di 15. Sep 2015, 09:24
Hab es schon auch mal mit diesen versucht aber ich bekomme es nicht hin.
Sub PDF_Export
Dim sUrl
Dim oService
Dim myProps(1) as New com.sun.star.beans.PropertyValue
    kPfad = ThisComponent.URL
    sPfad = DirectoryNameoutofPath("/media/archief/ANDRE MAP/")
    sUrl= sPfad & "/" & pdfName & ".pdf"
    myProps(0).Name  = "FilterName"
    myProps(0).Value = "calc_pdf_Export"
    myProps(1).Name  = "FilterData"
'    myProps(1).Value = Array(Array("SelectPdfVersion",0,1,com.sun.star.beans.PropertyState.DIRECT_VALUE))
   Dim myFilterData(1) as New com.sun.star.beans.PropertyValue
   myFilterData(0).Name = "SelectPdfVersion"
   myFilterData(0).value = 1
   myProps(1).Value = myFilterData
    ThisComponent.storeToUrl(sUrl,myProps())
    oService = createUnoService("com.sun.star.system.SystemShellExecute")
    oService.execute(sURL,,0) 'Reader wird automatisch aufgerufen
    Exit Sub
ICH MACH ETWAS FALSCH ABER WAS??????
Andreas
Atwist
Beitrag von Atwist » Di 15. Sep 2015, 10:41
Hab einen neue Variante gemacht aber Funktioniert auch nicht.
sub TestPDF
dim args1(0) as new com.sun.star.beans.PropertyValue
args1(0).Name = "ToPoint"
args1(0).Value = "$A$1:$D$35"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args1())
dim args2(2) as new com.sun.star.beans.PropertyValue
Dim CellRange As Object
CellRange = Sheet.getCellRangeByName("H1")
args2(0).Name = "URL"
args2(0).Value = "file:///media/archief/ANDRE%20MAP/ " & CellRange & ".pdf"
args2(1).Name = "FilterName"
args2(1).Value = "calc_pdf_Export"
args2(2).Name = "FilterData"
args2(2).Value = Array(Array("UseLosslessCompression",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Quality",0,90,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ReduceImageResolution",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("MaxImageResolution",0,300,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("UseTaggedPDF",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SelectPdfVersion",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportNotes",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ViewPDFAfterExport",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportBookmarks",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("OpenBookmarkLevels",0,-1,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("UseTransitionEffects",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("IsSkipEmptyPages",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("IsAddStream",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("FormsType",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportFormFields",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("AllowDuplicateFieldNames",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerToolbar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerMenubar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("HideViewerWindowControls",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ResizeWindowToInitialPage",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("CenterWindow",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("OpenInFullScreenMode",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("DisplayPDFDocumentTitle",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("InitialView",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Magnification",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Zoom",0,100,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PageLayout",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("FirstPageOnLeft",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("InitialPage",0,1,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Printing",0,2,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Changes",0,4,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EnableCopyingOfContent",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EnableTextAccessForAccessibilityTools",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportLinksRelativeFsys",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PDFViewSelection",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ConvertOOoTargetToPDFTarget",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("ExportBookmarksToPDFDestination",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignPDF",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("_OkButtonString",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Watermark",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("EncryptFile",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PreparedPasswords",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("RestrictPermissions",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("PreparedPermissionPassword",0,Array(),com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("Selection",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureLocation",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureReason",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureContactInfo",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignaturePassword",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),Array("SignatureCertificate",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE))
dispatcher.executeDispatch(document, ".uno:ExportToPDF", "", 0, args2())
end sub
Andreas
